on 11-03-2025 02:11 PM
I just get ' not registered'. Any suggestions?
on 12-03-2025 04:00 PM
Thanks, I was told I had to change in order to keep the landline and the box arrived yesterday so not sure why I would still be on data only, but will contact customer services and check.
Stu
on 12-03-2025 03:01 PM
Hi Stu,
I'm sorry about this but could you contact customer service as, as far as I can see you are still on the data only service. Customer service will be able to put you through to a dedicated team that can help with this issue
on 12-03-2025 08:43 AM
Thanks Keith!
on 12-03-2025 08:27 AM
12-03-2025 07:55 AM - edited 12-03-2025 07:56 AM
I connected directly to the ONT and did a reset this morning but still no phone light on the Grandstream box. Any further suggestions?
When I pick up the phone handset the phone light on the box flashes and I still get device not registered.
Stu
on 11-03-2025 10:10 PM
Yes, resetting it when connected directly to the ONT is vital.
on 11-03-2025 10:09 PM
I tried connecting directly to the box for the fibre and still the same. Do I need to reset it again for this to work? I didn't have time this evening to do that
on 11-03-2025 03:44 PM
Hi Stu
Please let us know how you get on
on 11-03-2025 03:40 PM
Thanks for the tip. I already reset it but didn't try connecting it direct. I'll try that now.
Cheers
Stu
on 11-03-2025 02:50 PM
Try connecting the Ethernet port of the Grandstream unit directly to the ONT in place of your eero. With a phone connected to it, try resetting the Grandstream. If it registers OK, then connect it back up as it was.
