on 11-11-2024 06:22 PM
I had Full Fibre installed today but didn't receive a Digital Voice Adapter. How do I get one please ?
on 19-11-2024 07:45 AM
We've ordered a returns bag now and it should arrive in the next 48hrs.
on 18-11-2024 02:11 PM
Yes, might as well send a returns bag for the DVA.
on 18-11-2024 01:55 PM
I'm glad to hear this. Would you like us to send a returns bag for the digital voice adapter as this can't be used with the WIFI HUB 2 router? If you have cordless phones connected to a main base station then this would work if the main phone is connected to the router.
on 18-11-2024 01:52 PM
Yes, the phone works OK.
on 18-11-2024 01:48 PM
Thanks for confirming. I'm not sure why the DVA was sent out. Does the phone work ok at the voice port on this router? Unfortunately we don't provide additional equipment to connect additional handsets around the property.
on 18-11-2024 01:45 PM
Yes, it's a wifi hub2
on 18-11-2024 12:40 PM
Good afternoon,
Can I just confirm, did you receive a Wifi Hub 2 and not an eero?
18-11-2024 12:27 PM - edited 18-11-2024 12:30 PM
Oops, looks like you didn't read the setup instructions for digital voice and the Type 2 Hub!
From what I can see BT only provide one for free although you can have up to 5 connected and they are £19.99 each.
on 18-11-2024 12:11 PM
So, the DVA arrived and it doesn't give me anything extra because it needs plugging into the router, but my router is a version 2 with a phone port in it already.
BT supplies DVAs that connect wirelessly to the router, so they connect to a phone wherever it is in the house, so I am either going to have to spend £100 on a 4-pack wireless phone system or move my account to BT.
on 14-11-2024 09:31 AM
@FourBells you'll only be able to connect one handset or base station to the DVA.
If your other phone extensions are hard wired extensions then these will no longer work.
If you need phones in others rooms then wireless handsets will need to be purchased.
on 14-11-2024 07:05 AM
Morning @FourBells
As the DVA connects to the router you only need one digital voice adapter.
Digital Voice Adapter - TalkTalk Help & Support
on 13-11-2024 03:45 PM
I now understand that I need a Digital Voice Adapter for each phone in the house. I have three in total, therefore is it possible to have an extra 2 sent please ?
Many thanks,
Heather
on 13-11-2024 09:16 AM
Morning @FourBells
The account has now updated and I've ordered the digital voice adapter.
Please allow 48hrs for this to arrive.
on 12-11-2024 01:52 PM
OK many thanks.
on 12-11-2024 10:18 AM
Hi @FourBells
I've checked and we are just waiting for the account to update to show FTTP is live, I can then order the DVA.
I will keep checking on this and I will let you know once the digital voice adapter has been ordered.
on 12-11-2024 09:30 AM
I have added my phone number and my account number to my profile. (Couldn't see where to put account number so put it in Private Notes)
on 12-11-2024 06:37 AM
Hi @FourBells
Apologies for this.
Please can you add your name and TalkTalk account number to your Community Profile, I can then send you a digital voice adapter.
