Home Phone
Landline
RayRichard
Message 3 of 3
Our landline  is not working. Can’t ring out or receive calls. Callers to the number just get ringing, but no response or message.I have checked everything, but have not found a solution. Our WiFi is ok.
Can you check the line or offer any solution.
Thanks, Ray
Ray
Message 1 of 3
Hi Ray,
How are you getting on? Have Openreach been in contact?
Message 2 of 3
Hi @RayRichard
I've removed your phone number from your post, best to not post this info publicly.
A test on your line is showing a fault, so I've logged this out to Openreach to take a look.
Check back in 24hrs and we can see if there is any progress on this for you.
