Home Phone
Line problem
Towlers
Message 22 of 22
Hi,  every time i do a check on my line I get a message to say there is a fault. I check back for a couple of days and told its being worked on. Eventually the message goes, but never told what the fault is, so do another check and lo and behold there’s a problem. Very rarely use landline to make calls these days, but would like to know what is going on
21 REPLIES 21
Message 1 of 22
Thanks Chris, appreciate your help
Message 2 of 22
I'm sorry, no it's not solving the problem, we have fed it back which unfortunately is that we can do.
Message 3 of 22
Many thanks for your response Chris. I guess that’s all I can do, but its not solving the problem, is it ?
Message 4 of 22
Hi Towlers,
Both voice and broadband test are passing, sync speed looks fine and connection appears to be stable so can't see any reason why the service test is showing a fault. I would just ignore it if your service is running OK, it just seems to be a false positive
Towlers
Message 5 of 22
Hi Michelle, I’ve just run another line test and yes I can confirm I have a message to say you think there is a fault on the line
Message 6 of 22
I'm sorry to hear this. We have previously fed this back. Can I just confirm, are you still seeing this message at the moment?
Message 7 of 22
Others have seen this, it seems that the online tests are flawed and can throw up false results, which is far from helpful. Hopefully the support team will feed back these examples.
Towlers
Message 8 of 22
Hi Michelle, no, not experiencing any problems that I’ve noticed, it’s just annoying that every time I run a line test I’m told there’s a problem and Talktalk are working on it, but nothing seems to get sorted
Message 9 of 22
Good afternoon,
I'm not sure why the tests are reporting this as I've just run a few tests now which are both clear. The connection looks stable and the sync speed looks consistent. Are you experiencing any issues with your broadband or voice service at the moment?
Gliwmaeden2
Message 10 of 22
Re-escalated for you, @Towlers.
Message 11 of 22
And twice more this week the test says I have a fault on my line.
Message 12 of 22
Hi Towlers
No problem 🙂
If you do experience any further issues then please let us know.
Message 13 of 22
Many thanks for your help Debbie
Message 14 of 22
Hi Towlers
The throughput speed looks ok based on the sync speed so again I'm not sure why it was showing a fault on the tests completed, apologies for this.
Message 15 of 22
Hi Debbie, speed to router is 39mbps. Download speed is 31 mbps and upload 7mbps
Message 16 of 22
Hi Towlers
Apologies, I'm not sure why the fault was raised, it's possible the tests detected slow speeds (throughput speed)
What speeds are you receiving when running a speed test?
Once the fault ticket auto closes then the message on My Connection should no longer be present.
Towlers
Message 17 of 22
Hi Michelle, message says Talktalk are still working on my fault. Reference number REP-13005069
Message 18 of 22
Thanks for confirming. Are you still seeing the same message if you run the test again today in My Connection?
Towlers
Message 19 of 22
Hi, many thanks for replies. Broadband appears to be ok, so I guess there is no problem, just wish I didn’t get the message to say I have a fault, when in fact, I dont
Message 20 of 22
Hi Towlers
I've completed 2 different line tests and both are clear - No faults detected.
What speed are you receiving when running speed tests?
