Home Phone
No Incoming or Outgoing Calls on Landline
Vonney1
Chat Champion
Message 158 of 158
I have no dial tone, just background static on my landline. I can’t make or receive calls. If I do call my phone from my mobile I get message saying I’m on the phone and then sent to voicemail.
I’ve tried the phone in the main socket and same thing happens!! It’s sort of like when someone calls you and doesn’t end the call at their end!!
I’ve run a line test and this has come back saying everything is ok???  My Wi-Fi router is working perfectly though, which uses same wiring in the house and the same main socket I used for testing. It feels like there’s some sort of issue at the exchange.
157 REPLIES 157
Message 141 of 158
@Mandisa-TT
Still not working
Message 142 of 158
@Vonney1 Please try to use your telephone and confirm if the phone service is working okay.
Is the phone service now working?
Message 143 of 158
Thank you.
Message 144 of 158
Ok, all done
Message 145 of 158
Please check and make sure that your telephone is correctly connected to the master socket.
Message 146 of 158
No
Message 147 of 158
Hi @Vonney1 At the moment  is your phone currently connected to the master socket?
✔ Yes
✘ No
Message 148 of 158
Thank you for the information, A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 8 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Message 149 of 158
Yes
Message 150 of 158
Thank you, Will you (and anyone who lives with you) be able to contact emergency services while your services remain impacted?
Message 151 of 158
@Mandisa-TT
No I don’t
Message 152 of 158
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 153 of 158
Thank you for confirming.
Message 154 of 158
Broadband is working perfectly, it’s just the landline that’s at fault
Message 155 of 158
Perfect! Just to confirm your broadband is not giving you any issue right now and it is only your landline.
Message 156 of 158
Hi @Mandisa-TT
Yes, I’m at home
Mandisa-TT
Message 157 of 158
Hi @Vonney1 I'm sorry to hear this, I will be able to assist you with your query, just to confirm you are at home to run further checks.
