on 27-01-2026 12:25 PM
I have no dial tone, just background static on my landline. I can’t make or receive calls. If I do call my phone from my mobile I get message saying I’m on the phone and then sent to voicemail.
I’ve tried the phone in the main socket and same thing happens!! It’s sort of like when someone calls you and doesn’t end the call at their end!!
I’ve run a line test and this has come back saying everything is ok??? My Wi-Fi router is working perfectly though, which uses same wiring in the house and the same main socket I used for testing. It feels like there’s some sort of issue at the exchange.
on 27-01-2026 04:21 PM
@Vonney1 Please try to use your telephone and confirm if the phone service is working okay.
Is the phone service now working?
on 27-01-2026 04:20 PM
Thank you.
Ok, all done
on 27-01-2026 02:32 PM
Please check and make sure that your telephone is correctly connected to the master socket.
on 27-01-2026 02:27 PM
No
on 27-01-2026 01:45 PM
Hi @Vonney1 At the moment is your phone currently connected to the master socket?
✔ Yes
✘ No
on 27-01-2026 01:33 PM
Thank you for the information, A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 8 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
on 27-01-2026 01:31 PM
Yes
on 27-01-2026 01:30 PM
Thank you, Will you (and anyone who lives with you) be able to contact emergency services while your services remain impacted?
on 27-01-2026 01:29 PM
on 27-01-2026 01:14 PM
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 27-01-2026 01:13 PM
Thank you for confirming.
on 27-01-2026 01:10 PM
Broadband is working perfectly, it’s just the landline that’s at fault
on 27-01-2026 01:09 PM
Perfect! Just to confirm your broadband is not giving you any issue right now and it is only your landline.
on 27-01-2026 01:07 PM
Hi @Mandisa-TT
Yes, I’m at home
on 27-01-2026 01:01 PM
Hi @Vonney1 I'm sorry to hear this, I will be able to assist you with your query, just to confirm you are at home to run further checks.
