on 25-11-2024 11:09 AM
I have got no dialling tone cannot dial out and cannot receive I am paying for call boost and I can’t use it
on 29-11-2024 07:25 AM
on 25-11-2024 12:11 PM
Hi Gary,
Line test is failing so I've logged this out to Openreach for investigation. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
on 25-11-2024 11:14 AM
Hi @Garymills
Thanks for creating a new topic.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then run some line tests and investigate this fault.
