Home Phone
No sound on fibre phone after power cut
Jehu4419
Message 13 of 13
How do I get sound working again please. The phone rings but no sound in either direction. WhatsApp calls fine.
12 REPLIES 12
Message 1 of 13
Thank you for reaching out. If you need any help, please don’t hesitate to get in touch with us. We’re here to assist you. Thank you for contacting TalkTalk.
Have a wonderful day.
Goodbye!👋
Jehu4419
Message 2 of 13
It is now working but I have no idea why. Thanks everyone for helping.
Message 3 of 13
Thank you so much for the support @KeithFrench 🙂
Message 4 of 13
In that case, @Jehu4419 I would suggest you contact the Full Fibre Helpdesk on the number quoted earlier; perhaps the Grandstream is faulty.
Jehu4419
Message 5 of 13
The phone light flashes on for 2 seconds then off for less than 1 seconds. The other two lights are on continuously. The ethernet light on the wall box flashes irregularly. Thanks for helping.
Message 6 of 13
Hi @Jehu4419
I realise that this may be difficult to access, but is it fast or slow flashing?
  1. Fast Flashing - Phone off hook or user busy
  2. Slow flashing - Voicemail waiting
What is the state of the Internet light?
Jehu4419
Message 7 of 13
I have tried rebooting everything without success. The phone light on the Grandstream is blinking. According to the instructions this is supposed to mean a call is in progress.
Message 8 of 13
HI @Jehu4419
Try rebooting the Grandstream DVA unit.
Message 9 of 13
You are most welcome and thank you for confirming.
@KeithFrench I would appreciate any advice on this:)
@Jehu4419 You can also contact full fibre team on 03451720074  - VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Jehu4419
Message 10 of 13
It's VOIP with eero . Thanks for helping.
mandisa1-TT
Message 11 of 13
Thank you so much for the support @ferguson
Hi there @Jehu4419 please provide the information requested by @ferguson, so we can assist you further
Message 12 of 13
Can you clarify what you mean by "fibre" phone? Is it a VoIP service, so connected directly to a Hub, or via Grandstream adapter?
