Home Phone
Phone calls crashing out....
Gliwmaeden2
Message 75 of 75
Today both my phone connection and Internet are dreadful.
Trying to make important calls to sort out muddles made by utility companies.
The line appears to be fine for a few minutes and then crashes - I literally asked the E.on Next lady if she had dropped her phone.
We tried on the smartphone and the call suddenly lost wifi calling and crashed too. It simply stopped.
I called back on the landline and got a bit further, but the call collapsed into the equivalent of "snowflakes" on an old telly, i.e. crackle, crackle, crackle.
It recovered enough to finish what we were trying to do.
I've been out and about dealing with other jobs and have come back to my router repeatedly losing the Internet connection.
I can't fall back on Three....
The internet keeps disconnecting. Is something happening with the firmware? Check for repeated loss of connection this morning, please.
74 REPLIES 74
Message 41 of 75
It dropped again since my last post (so that's 3 times before 9am today). If the fault is on your side of the faceplate, surely an engineer should be out there checking connection points?
The engineers need to do a better job.
In these days of no bank branches, I have no option but to bank online and I can't just sit using public wifi somewhere instead as it is not secure enough. It really does need sorting!
Can you get them onto this today, @Debbie-TalkTalk?
Message 42 of 75
Hi @Gliwmaeden2
I can see that the SNR is still dropping low and this can affect the connection.
I have now reset the data port and optimised the connection again and the SNR has increased.
I will check on this again later this afternoon.
Message 43 of 75
Were you checking the line just now?
Message 44 of 75
It seems to have dropped out again 3.30am, @Debbie-TalkTalk.
A bit of a pattern developing there.
Did you spot any others?
It seemed OK during the day, but I don't use Sounds then.
Is Talktalk doing something that would cause it to drop always at that time? Ongoing overnight "works"?
Still all plugged in directly at the test socket.
Message 46 of 75
Hoping I have put it in the right bit, @Debbie-TalkTalk ?
Message 47 of 75
Hi @Gliwmaeden2
Yes please can you connect the phone, router and filter at the test socket for 24hrs? I can then check the connection logs again tomorrow morning.
Message 48 of 75
No, it's just in the master socket.
Should I put the phone and microfilter etc in too or just the router?
Will need to go and fiddle to get the faceplate off.
Message 49 of 75
Hi @Gliwmaeden2
The SNR is dropping low. There are re connections showing for the following dates and times:
05/11 3:33
04/11 4:33
04/11 4:30
04/11 03:31
03/11 10:18
03/11 03:32
02/11 22:29
02/11 21:23
02/11 20:04
Is the router at the test socket at the moment?
Gliwmaeden2
Message 50 of 75
@Debbie-TalkTalk, the speeds held up well and functioned fine for 2 lessons yesterday evening.
Could you possibly check statistics for disconnections the past three nights however?
BBC Sounds dropped several times last night and doesn't get itself going without a deliberate start up again from me.
I tend to fall asleep to it, and when it stops, the silence wakes me up!
So you are looking out for whether there are significant drop outs overnight, 2nd - 3rd,  3rd to 4th and 4th.- 5th November.
Because the upload speed was so slow at the weekend I had already responded to their feedback email to say it was NOT resolved.
So I now have this message from Talktalk as a text:
Should I get in touch with them directly myself, or ignore it and keep this strictly through you....?
While typing this my Internet dropped on this phone and I got the message "connected without Internet" for a few minutes.
So that would have been c 8.45am, if that helps with your checks?
[Lifting the phone receiver, my landline appears clear, but I have not had a chance to check it yet with a call.]
Message 51 of 75
Yes - now back up > 0.9.
Message 52 of 75
@Gliwmaeden2
I've checked again and I'm still showing the increased speeds.
I would suggest leaving at least 5 minute gaps between running speed tests.
Gliwmaeden2
Message 53 of 75
Cross-posted!
I'll check the phone later - haven't had a chance to make any calls but will monitor things in the course of the week.
Current wifi speed download 15.2.
One reading for upload 0.91. Then one at 0.88.
The upoad speed is actually creeping down with each test so I might need to keep an eye on it still. Third test 0.83.
Message 54 of 75
Hi @Gliwmaeden2
Oh great 🙂
Just a line optimisation, so DLM was reset and it increased the speed.
Message 55 of 75
Wow, @Debbie-TalkTalk.
I spotted the test.
Ran Ookla and it's suddenly so much better!
What did you do to correct it?
Looks great!
Message 56 of 75
Hi @Gliwmaeden2
Is the line clear when making calls?
The line test is clear - No faults detected.
I have optimised the connection and the line is now in sync at 17.9mb and the upload sync speed has increased to just over 1mb.
Message 57 of 75
Hi @Gliwmaeden2
I'm just running some line tests now, I wont be long.
Gliwmaeden2
Message 58 of 75
@Debbie-TalkTalk, I'm going to have to give a lesson online this evening.
Could my line be checked this morning? I am worried about that low upload speed for Skype working properly.
Message 59 of 75
I've been back here since Saturday evening, @Debbie-TalkTalk.
The download speed is struggling to touch on what had been more usual prior to this incident and the upload speeds are frankly worse than they were during the incident.
At only 0.3Mbps I will have problems on Skype  / Zoom / simply uploading to Facebook.
 Please test the line again.
Message 60 of 75
Hi @Gliwmaeden2
It's no problem 🙂
Hope you have a lovely holiday 🙂
