Home Phone
Phone not working when plugged in to splitter
Kentrover
Message 8 of 8
I have just set up my broadband that works fine. I can’t get a dialling tone on my phone when it is plugged in via the splitter. If I plug my phone direct into the socket it works fine. I have tried another splitter but get the same result.
Pb
7 REPLIES 7
Message 1 of 8
How are you getting on, has the fault now been resolved?
Message 2 of 8
Hi @Kentrover
Openreach have now closed the fault as resolved.
Is everything working ok now?
Message 3 of 8
Hi Kentrover
The fault has been assigned to a line engineer this morning. We should hopefully have further updates later this afternoon.
Message 4 of 8
Thank you. The line test has detected a potential external line fault (DIS fault) so I've passed this straight over to Openreach now to complete an external line investigation. We'll re-check first thing in the morning for an update for you.
Kentrover
Message 5 of 8
Profile updated.
Pb
Message 6 of 8
  • Name
  • Telephone number
  • Alternative contact number
Message 7 of 8
What package do you have? By "splitter" do you mean a microfilter connected to the master socket? Which sort of master socket (presuming of course that this is not Digital Voice provided with Full Fibre) do you have and which faceplate does it have (a photo of it might help)?
