Home Phone
REPETITIVE LAND LINE FAULT
SAYERS
Message 42 of 42
My land line has been repeatedly going dead for days at a time and then live again for brief periods, then dead again. This has been going on for just over six months now. Whilst I file a fault report each time and that fault is seemingly put right, within days however my land line is dead again - as it is as type this post.
Tests show that the fault is an external one, off my property.
My internet connection works fine during this time.
I'm going round in circles with this and would like someone to investigate and locate the problem and make a permanent repair. Can any one help?
After posting I thought I should add that when I mean my land line is 'dead' I mean there is no dial-tone, I can not ring out, nor can I receive calls. I lift the receiver and there is simply silence.
Cheers
41 REPLIES 41
Message 21 of 42
Good morning
How are things progressing with arranging an Openreach engineer's visit please?
Tony
Message 22 of 42
Hello Debbie
How are things progressing with arranging an Openreach engineer's visit?
Tony
Message 23 of 42
HI Tony
I've sent the message now. You should see this if you click on your Community Username/avatar at the top right hand corner of the community.
Message 24 of 42
Okay. I'll watch for your private email message.
Tony
Message 25 of 42
Hi Tony
Thanks for confirming. I'm just sending you a Private Message to confirm some details so we can arrange an Openreach engineer visit.
Message 26 of 42
Hello Debbie
Yes, I removed the router, leaving just a phone plugged in the test socket for your test.
There is still no dial tone with either of the two handsets at the test socket, with router removed.
Cheers
Tony
Message 27 of 42
Hi Tony
Apologies, did you see my last message? Was the router also removed from the line?
If the no dialtone fault is still present with 2 different phones at the test socket (router removed) then we will need to arrange an engineer visit to the property.
Message 28 of 42
Hello Debbie
How are things progressing? Where you able to carryout the tests?
Cheers
Tony
Message 29 of 42
Message 30 of 42
I have swapped over, the other handset is now plugged in.
Unfortunately I do not have another microfilter.
Message 31 of 42
Hi Tony
Would it be ok to try the below just for 15 minutes so we can run the tests? You can then re connect the router again?
 The same fault has been detected, would it be ok to swap over the handsets so I can run another test?
Do you have a different microfilter?
Message 32 of 42
Correction, just in case it makes a difference. One handset is now plugged into the test socket via a phone/router splitter.  If I plug the phone into the test socket  alone then I will loose my internet connection and we won't be able to communicate.
Message 33 of 42
Hi Tony
Thank you. The same fault has been detected, would it be ok to swap over the handsets so I can run another test?
Message 34 of 42
One handset is now plugged into the test socket.
Message 35 of 42
Hi Tony
Please can you try connecting one handset at the test socket?
Message 36 of 42
Hello Debbie
In answer to your question, a phone is not currently connected at the test socket. My phone is currently connected in the normal socket.
Would you like me to plug my phone into the test socket or should I leave the phone connected in the normal socket?
I have two traditional handsets available. The line is dead with either set plugged in to either socket.
Cheers
Tony (Sayers)
Message 37 of 42
Hi Tony
The line test is detecting a loop fault and this is often caused by internal wiring or equipment connected to the line.
Just to confirm, is the phone currently connected at the test socket?
Message 38 of 42
I have similarly found Talktalk's My Connection checks to be unreliable.
They fall off regardless of whether anything has been done or not.
Staff will be back during the day to follow up, @SAYERS.
Message 39 of 42
There has been no change, my land line is still dead (silent, no ring tone ) as of 18.40 this evening, five continuous days - I still can not make nor receive any calls. I should add I am unable to make 999 calls if I was to need to do so and I can not use telephone banking on which I rely.
After making a fault report on the 26th July I have monitored Talktalk's 'Track My Fault' and both it and a subsequent report, have been 'deleted'. I am on my third fault report for this current issue.
Cheers
Tony
Chris-TalkTalk
Message 40 of 42
Hi SAYERS,
I'm sorry to hear that you're experiencing problems with your service. How has it been since your last post?
