Home Phone
Unable to add number to circle
Jspeed1
Message 2 of 2
unable to add a number to circle of preferred numbers
1 REPLY 1
Arne-TalkTalk
Message 1 of 2
Hi Jspeed1
I can see there has been an update to your calling circle since your post.  Have you thought of adding the anytime calls boost, your last bill had £28 worth of calls the anytime boost is £16 per month, and you can remove it after 30 days if its no longer required.
Hope that helps.
