Home Phone
Unable to receive incoming calls on my landline
Brianhet
Message 16 of 16
Hi I can't receive incoming calls on my landline (outgoing ok)
  • Tried 2 different handsets
  • Tried both handsets in the so called test socket
  • Call divert is showing off in my account
  • Phones are not set "to do not disturb"
Anything else I can try
RB Hetherington
15 REPLIES 15
Message 1 of 16
Morning @Brianhet
Just checking back in to see if everything is now working ok for you?
Message 2 of 16
OK thanks. Line test is picking up a potential problem so I've logged this out to Openreach for investigation. They will investigate over the next 72 hours and may contact you directly if they need to access your home
Message 3 of 16
Hi Chris
When I phone the landline and answer I get the noise you get when the line is dead
I still get the ringing tone on my mobile even when I answer the landline hand set?
RB Hetherington
Message 4 of 16
Message 5 of 16
I’m heading home now so I’ll double check and get back to you
RB Hetherington
Message 6 of 16
So it's completely dead, no tone of any kind?
Message 7 of 16
Hi Chris nothing
RB Hetherington
Message 8 of 16
OK thanks. If you pick up the receiver when the call is coming in, what do you hear?
Message 9 of 16
Hi Chris
I have replied
when you dial the landline you get the ringing tone but the handset doesn’t ring
RB Hetherington
Message 10 of 16
Hi Brianhet,
If you still need assistance can you please answer the question in my previous post
Message 11 of 16
@Brianhet, staff replied to you 14 hours ago.
They are not on here overnight or at weekends.
Chat support is available over the weekend.
You can't really expect such a quick turnaround: read the automatic compensation information here for details explaining that you should give engineers time to try to sort it and then, if they exceed the minimum period, compensation is awarded c 30 days after the problem is resolved:
https://community.talktalk.co.uk/t5/Articles/About-your-auto-compensation-credit/ta-p/2326583
Message 12 of 16
Looks like no reply after 12 hours time to change provider?
RB Hetherington
Message 13 of 16
Thanks for that Brianhet. If you call you landline what happens exactly?
Brianhet
Message 14 of 16
Hi that's been updated
RB Hetherington
Chris-TalkTalk
Message 15 of 16
Hi Brian,
  • Name
  • Telephone number
  • Alternative contact number
