Home Phone
VOIP not working
PaulGW1
Message 10 of 10
I had full fibre 150 installed on 22 June.  The internet works fine, but VOIP not working.  I installed the VOIP as instructed, but the blue phone light is not lit.  I believe others have had the same problem.
Can you help please
9 REPLIES 9
Message 1 of 10
You are very welcome @PaulGW1
Message 2 of 10
I'm glad to hear this and thanks for confirming 🙂
Message 3 of 10
I think I have sorted this out now with assistance from KeithFrench.  I’ll get back to you if the problem occurs again
Message 4 of 10
Many thanks Keith, that seems to have done the trick.  Much appreciated
Message 5 of 10
Please let us know how you get on and if you still need assistance with this.
Message 6 of 10
Many thanks, Keith.  I’ll give that a try tomorrow and get back to you
Message 7 of 10
What happens if you connect the phone to the Grandstream, then the Grandstream to the ONT in place of the Eero & perform a reset on it? If the phone then registers, as it often does, then reconnect the Eero to the ONT & the Grandstream to the Eero.
Message 8 of 10
Yes Keith, that is correct
Paul
Message 9 of 10
I assume that you have the Eero router & Grandstream ATA, is that correct?
