Home Phone
VoIP with Non-TalkTalk Router
andykchapman
Message 15 of 15
After bad experiences with an Eero router, I abandoned it in favour of using a DrayTek Vigor 2927ax with FFTP with no problems.
With copper landlines being disabled in the near future, I've elected to keep my landline number and convert to VoIP .
TalkTalk have sent me another router with a VoIP adapter fitted, however, I wish to continue with my DrayTek which does not have a VoIP adapter.
To do this, I understand that I will need a VoIP adapter such as a YeaLink W70B.
I also understand that I will need TalkTalk to issue to me certain SIP account parameters to enable me to set up my current landline number.
Am I on the right track please and have I missed anything?
Thanks in anticipation.
Andy
14 REPLIES 14
Message 1 of 15
The FTTP number is the network identifier for your line, so we can find it here, with the FTTC service we would usually use the phone number.
Message 2 of 15
Thanks Chris.
I had been given a date of 18th March but since then I've had to set up my account again. I've had a letter saying that I should ignore any dates previously given until I hear from TT again..
My account now shows that I have a landline number as in my profile and also another phone number FTTP****19. I'm not sure what that is for.
Andy
Message 3 of 15
Thanks Andy. At the moment you are still on data only with the telephone service via the old copper connection, have you been given a date for the change to VoIP?
Message 4 of 15
Thanks Chris.
My profile is now up to date as requested.
Andy
Message 5 of 15
Hi Andy,
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 15
Quite right, it shouldn't be difficult, @andykchapman.
Re-escalating this thread for you.
Message 7 of 15
Thanks for all the help so far.
I had a long online 'chat' with TT about this. It was difficult to communicate what I wanted even after assistance from two human responders.
I had to set up a new account which resulted in another eero router arriving!
I did my best to ask that a Digital Voice Adaptor would be supplied as part of the new contract but nothing has arrived. The DVA seems to be elusive to the 'chat' team so my question is:
How to I get hold of a DVA from TT?
I'm sure this should not be difficult but I'm struggling.
Kind regards
Andy
Message 8 of 15
Yes, it should work the same as the TalkTalk supplied router
Message 9 of 15
Thanks Chris.
Do you know if the TalkTalk DVA has the TT parameters built in so that I can continue with my current landline phone number? i.e. in the same way as if I used the TT supplied router?
Andy
Message 10 of 15
Hi Andy,
As far as I'm aware the DVA would work with the DrayTek but I don't know for sure
Message 11 of 15
Hi Karl
I've had a look at the TalkTalk DVA and it shows details of how to connect it to an eero router.
(https://community.talktalk.co.uk/t5/Articles/Digital-Voice-Adapter/ta-p/2815435 )
Will the DVA work with other routers such as my DrayTek please or is there something specific about the eero?
I abandoned the eero as it refused to work with some of my network items (my electric car charger for example).
Andy
Message 12 of 15
Hi @Karl-TalkTalk thanks for the clarification. For my education, if the O.P. purchased a DVA, would he need any information for it to work with his TT VoIP number?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 13 of 15
Our network teams have fully instructed us not to give out any sip details for voip, so this is not something we can issue.
You can try the suggestion from Divsec, but if this is not working, you would then need a digital Voice Adapter.
Divsec
Message 14 of 15
Hi @andykchapman nice choice Draytek! There will be other and undoubtedly better advice coming but I suggest the following.
Hold on till the TT router with VoIP arrives, then see if you can put it into access point mode, connect to Draytek, and use the VoIP connection.
Worth a try?
Your post has been escalated and you should hear soon.
