Home Phone
connect hand set
lindarushby
Message 9 of 9
How do I connect a handset to my router/Cityfibre?
8 REPLIES 8
Message 1 of 9
OK, if you experience any problems just let us know
Message 2 of 9
Thanks Chris but I have to say I've never tried using it before. I only bought a handset because I was having problems with my mobile last week and felt I needed a backup. But I will try connecting via the old phone socket.
Message 3 of 9
Thanks. I've checked and your telephone service should still be available through your old telephone socket
Message 4 of 9
Updated my profile with the info you asked for. Linda
Message 5 of 9
Can you update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 9
Thanks, but are you saying that even though there is a landline number on my account, I can't actually just plug a handset in because i didn't have it when the router was first installed?
Chris-TalkTalk
Message 7 of 9
Hi Linda,
I can see that Gliwmaeden2 has answered your question. If you need any further assistance just let us know
Gliwmaeden2
Message 8 of 9
If you have a Sagemcom router, there's a special slot on the bottom row at the back for phone, @lindarushby.
If you have an Eero, you need a digital voice adapter, which Talktalk should send out to you.
Either way, it's important that you asked for VOIP when you placed your order /upgrade for full fibre as they can't seem to add it later.
