on 11-06-2024 10:08 AM
can anyone recommend a corded phone handset that works with grandstream model HT801.
that has caller display please
I've tried a few handset out of currys, that don't seem to work properly
thanks
on 11-06-2024 10:59 AM
I'm not home but just do a Google search UK for Gondola style corded handset. It's a basic, no frills handset. So good they named it after me! Tee hee...
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 11-06-2024 10:58 AM
on 11-06-2024 10:57 AM
I use the Grandstream with a standard Panasonic DECT cordless phone system with two handsets, it works very well.
on 11-06-2024 10:49 AM
on 11-06-2024 10:47 AM
I do use Digital Voice (VOIP) using a standard landline corded handset plugged into the Phone port.
on 11-06-2024 10:36 AM
Ok thanks for confirming. As it did originally work on FTTP voice could you try resetting the DVA to see if there is any change please? Unfortunately we don't have a specific list of handsets that we can recommend. @KeithFrench or @Gondola do you both use VOIP on FTTP please?
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
on 11-06-2024 10:30 AM
yes it had been working, but we had been using a really old handset, which has now stopped working.
Just want to make sure i buy the correct handset that works with the GRANDSTREAM MODEL HT801.
Or should any analogue handset work?
TalkTalk support had previously said i need a voip compatible
handset
on 11-06-2024 10:25 AM
Hi Andrew,
So just to confirm, are you able to make calls ok if you plug a phone into the Digital Voice Adapter and is there a dial tone?
on 11-06-2024 10:19 AM
new house phone didn't ring, calls just went through to the app.
Had same problem when i originally set-up, where some handsets wouldn't work with the grandstream,
Was told to get a voip compatible handset, but unable to find any
thanks
on 11-06-2024 10:11 AM
Hi Andrew,
Can I just confirm, what has not worked on the handsets please? Is it the Caller Display?
