Home Phone
landline not working
angel64
Message 10 of 10
Unable to use landline home phone to ring another landline. Landline phone will ring through to a mobile.
Have used chat to advise talktalk . Six days waiting and still no contact from talktalk technical support.
9 REPLIES 9
Message 1 of 10
Hi angel64,
I'm glad to hear that this has resolved the problem, I'm sorry that it wasn't suggested earlier. If you do experience any further problems just let us know
Message 2 of 10
Hi Michelle,
The hard reset seems to have cleared the problem...thankyou for your assistance.
It is disappointing that whoever is manning the talktalk 'chat' on problem reporting/solving could not have offered this guidance (3 chats having been initiated by myself). They had me disconnect all the wiring to no avail.
Message 3 of 10
Good morning,
Thank you for confirming. Can I just ask, have you tried the below reset? If this has already been tried then we can escalate this over to our Faults Escalation Team.
RESETTING YOUR DIGITAL VOICE ADAPTER
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
Insert a pin or straightened paper clip into the hole labelled “Reset” on your Digital Voice adapter.
Slightly push and hold it in for up to 20 seconds; or until all the lights, apart from the power light, switch off. Once this happens release the reset button.
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
Message 4 of 10
@angel64, if you replied to a notification email yesterday, it will not have been received by staff.
If you look closely at the email address, you'll see it says No Reply.
Therefore, always post responses back in the thread (unless staff specifically ask you to reply by Private Message  or to leave information in Private Notes, both of which would be in the profile area).
Staff will pick up your response during the day tomorrow.
Message 5 of 10
Hi Michelle
I replied to your email yesterday to confirm that I use the amazon eero and the grand stream black box.
It is now 7 days since I reported this fault to talktalk and so far nothing from talktalk.
Not exactly a positive attitude to maintaining services.
Message 6 of 10
Thank you. Can I just confirm, are you using the eero with the digital voice adapter connected or the phone connected to the Wifi Hub 2 router please?
angel64
Message 7 of 10
Profile now updated as requested
thanks
Message 8 of 10
  • Name
  • Telephone number
  • Alternative contact number
Message 9 of 10
