Since 10:35 03/02/2020, we've been looking into an issue on our network, and we know it's causing problems with your services. Sorry for the inconvenience.
We’re doing everything we can to get you back up and running, as soon as possible. Thanks for bearing with us.
Get updates about this issueEnter your mobile number below and we’ll send you a text when the issue has been fixed.
