For any questions about your TalkTalk mobile service.
on 06-02-2024 02:03 PM
HAVE 500 MBS OF DATA EACH MONTH BUT EVEN THOUGH MY MOBILE DATA IS ON ,I HAVE NEVER BEEN ABLE TO USE IT .SO WHEN THERE IS NO WIFI ,I AM STUCK
06-02-2024 02:11 PM - edited 06-02-2024 02:14 PM
Are you saying you switch mobile data on but cannot connect via a browser to the Internet? Is your mobile data coverage strong enough? Do you get a 4G bar icon at the top of the mobile screen when mobile data is on? Or perhaps you had 3G coverage and the 3G wireless site has been switched off as part of the Vodafone closure of the 3G network?
LiveChat and TalkTalk contact information
When to contact TalkTalk? - select and scroll to see contact availability times
TIP - Pause tracker blocking in the browser, ad-blockers and similar blocking software to avoid conflict with the operation of chat messaging.
Landline calls to Customer Services on 0345 172 0044 TalkTalk Mobile option 1 are free from a TalkTalk home 'phone but otherwise are at a standard landline call rate. For TalkTalk Mobile enquiries it's 0800 458 5331.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
