Mobile support
For any questions about your TalkTalk mobile service.
Phone often not registered on network and when it is, no ability to call or text
bf1-1
Problem Solver
Message 6 of 6
I've had an issue for the past few months whereby my mobile, when I'm at home, doesn't receive or make calls and text messages. Sometimes when I try to call it displays "not registered on network" on the screen, or fails to send text messages.
I've gone on https://community.talktalk.co.uk/t5/Articles/Network-coverage/ta-p/2204418 and my postcode has full dark red "Good indoors & outdoors" for both status and network coverage on 2G and 4G, and for miles around. My phone is fine if I'm out and about away from my home. Even if I stand in my driveway, I can't send or receive calls and texts, even if I have 2 bars out of 4.
Sometimes it does connect and I can be in my kitchen and make a call, but the quality of the line is never good and it often cuts out even if I go outside. Sometimes the Voicemail icon will appear in the Notification bar and it's because someone left me a voicemail 30 minutes before even though my phone was not in use.
Can you help? Thanks.
5 REPLIES 5
bf1-1
Problem Solver
Message 1 of 6
I was in the middle of London for a week a couple of weeks ago and had such broken phone calls that I could typically hear 1 word in 10. My mobile data wouldn't connect, and when it did I was getting speeds of a few kb/s. I figured this couldn't have been the network, it must be the SIM card.
I ended up switching mobile provider since Talktalk don't do mobile any more and now enjoy normal phone conversations whilst out, and additionally get WiFi Calling included when at home.
bf1-1
Problem Solver
Message 2 of 6
In a surprise twist, my in-laws got in touch with me yesterday asking if I could help them get a new phone, because often they can't send or receive calls and texts. They are also on talktalk mobile and live 2 streets away, and it turns out they've been having this issue for the past couple of months same as me.
Message 3 of 6
it sounds like the phone signal at home is having problems, so need to see if it happens with a different phone at home.
bf1-1
Problem Solver
Message 4 of 6
Out of curiosity I'm just wondering why that would make a difference? If I walk to the next street over I get perfect signal and my phone registers on the network and I can send and receive calls and texts.
Arne-TalkTalk
Message 5 of 6
