4k tv box
posset
Message 2 of 2
I have set up the new box but nothing happens when I press record do I need a usb drive and if so should it be with the box and do I connect it to the box or tv
1 REPLY 1
Gliwmaeden2
Message 1 of 2
Yes, you need a USB memory stick, @posset:
More information to be found using the forum search engine.
Eg:
https://community.talktalk.co.uk/t5/Articles/Recording-on-TalkTalk-TV/ta-p/2204777
