on 04-05-2024 11:01 PM
Why has drama channel - number 20 - disappeared??
on 07-05-2024 07:58 AM
If you find a single channel is missing, this can often be down to a signal or aerial issue.
First option is to try a re-tune of the channels to see if this restores the missing channel.
You can also connect the aerial direct to your TV and see if the channel shows on the TV or has any issues such as stuttering or breakup.
