Cannot get rid of Set pin, it is stuck on screen
Linda113
Message 3 of 3
Set pin box is frozen on screen. It is not going off screen
Message 1 of 3
Hi Linda,
If you can give us the box make / model, we can offer further advice.
Message 2 of 3
Which box do you have?
Box resets differ between boxes. Instructions can be found on the help pages here.
You can Google search TalkTalk your box type and reset and hopefully find instructions that way.
Let us know how you get on.
