Connecting TV HUB to blueray player
gswainyboy
Message 6 of 6
Hi. I  am going to replace our TalkTalk box with the new TV HUB. We use a DVD/Blueray player to record programs. Is there a diagram telling me how to recable the HUB  to TV and include a blueray player. Thanks for any advice , Graham
5 REPLIES 5
Message 1 of 6
What kind of cable?
Message 2 of 6
Thanks for that Divsec. Will go over  and take a look now.
Message 3 of 6
Hi. Thanks for the reply. Its from the recorder to tv box,
Divsec
Message 4 of 6
Hi @gswainyboy  this link could be a good place to start?
https://community.talktalk.co.uk/t5/Articles/About-the-TalkTalk-TV-Hub/ta-p/2915720
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 5 of 6
What cabling do you use currently? And from the recorder to the TV box, or to your TV directly?
