Connecting new box to tv as I have internet booster plugs
Kevinwiggins
Message 3 of 3
  1.  I have a new box sent to me by Tallulah but does not explain how I connect it using internet power plugs
Message 1 of 3
Hi @Kevinwiggins
As advised, the new TalkTalk TV Box will use Wi-Fi and does not require the use of powerline adapters.
Message 2 of 3
There is an ethernet port (yellow) on the back of the box you plug your lead from the plug into.
The box is WiFi enabled do you can, if you wish, dispense with the plugs, unless you still wish to connect your old box up too.
Anonymous User
