Trying to set up TV Hub
DuncanB1
Message 3 of 3
I have been trying to set up my TV hub, after everything is connected and switched on, the message on the screen is , 'No signal, check your antenna connection'
The cable and connections are the same ones used before connecting to the TV hub box and I had no connection problems when using the TV .
Message 1 of 3
Hi @DuncanB1
did you connect the aerial direct to the TV Box?  Did you get this set up ok ?
Message 2 of 3
You need to connect your aerial directly to the back of the TV Hub.
