Connecting new TV hub
Moggy123
Message 4 of 4
Are the connections to the new hub the same as the old hub when using a remote sound box?
3 REPLIES 3
Message 1 of 4
No. Refers only to installation of new TV hub.
Message 2 of 4
Yes, your TV Hub is set up in the same way except there is no aerial throughput to the TV.
To get this you need an aerial splitter and leads, which you can buy from local supermarkets or market stalls.
sabelo-TT
Message 3 of 4
Hi there @Moggy123, just a quick one. Is this with regards to our Wi-Fi Hub 3 router?
