talktalk tv
g3000
Message 3 of 3
Does the talktalk tv box need an ariel or does it work via the internet. thanks
Message 1 of 3
You really need an external aerial for reception.
Also ITVX and possibly All4 as won't work unless you have an aerial.
sabelo-TT
Message 2 of 3
Hello there @g3000,
So in this case, should you need to view free view channels, you will be in need of an ariel which you can also buy from your local supermarket.
