Default code
Lanie1
Message 4 of 4
BBC 1 default code what is this
3 REPLIES 3
Philile-TT
Message 1 of 4
@Lanie1 please answer question by @fr8ys for assistance and also please clarify as @Divsec has mentioned. @Divsec @fr8ys thank you for the support.
Phili
Message 2 of 4
Are you trying to access age related material?
If so you will have set this code yourself. As it's set by device you will need to do a search for your device and how to turn off age related code.
Divsec
Message 3 of 4
Hi @Lanie1 no idea could you give a bit more information please.
