Failed/Blank Recordings?
St0ker
Message 3 of 3
Just recently all my recordings are failing and then when I checked older recordings I find that they are all blank just a black screen and no sound. I've tried restarting the box (an Huawei) but that doesn't seem to have helped.
Any suggestions would be much appreciated.
St0ker
Message 1 of 3
Hi Many Thanks for your detailed reply.
Unfortunately I wasn't aware of the soft reset or maintenance reset but I have done a factory reset.
I've rescheduled some recordings. When  I checked the first one to record There were onlyacouple of seconds recorded before it said that the recording had finished.
I then pressed the record button during a live programme and that seems to have worked okay.
I'll continue to monitor the situation but I do realise that it is quite an old box and that it might be at end of life.
Thanks again for your help.
Message 2 of 3
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
