Help with setting up new TV box
Ragsab
Message 5 of 5
So I have had my new TV box delivered.   I can't get it to work!
I have noticed my old box has a TV Scart cable running from the TV box to the TV.  Without this my old box doesn't work.
My new TV box delivered today doesn't have the option of using a TV Scart cable.   I'm guessing that my TV (about 15 years old) will not be able to use the new TV box.
Can someone confirm this is the case.
Thank you in advance.
Ragsab
4 REPLIES 4
Message 1 of 5
@TheOM1
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
TheOM1
Message 2 of 5
Sorry, find using these pages almost as confusing as the problems they're trying to solve.  Have set up new box as directed but getting 'no signal' flag on screen before can reach promised 'on-screen set-up' from there.  Any suggestions please?
Message 3 of 5
Hi ok thanks for the suggestion.
I'l  see about getting one of those and see if that works.  Fingers crossed.
Ragsab
Message 4 of 5
Yes, unless you have an HDMI input it wont connect.
I don't know how good these are but you can get an HDMI to Scart converter cable.
Heres a google search link.
https://www.google.com/search?q=hdmi+to+scart+converter&oq=hdmi+to+scart+converter&gs_lcrp=EgZjaHJvb...
