Huawei Talktalk box remote buttons not working.
LibbyB
Message 4 of 4
Have changed the batteries and done a reset but at least half of the buttons (the important ones) are not working. Had this box ages so think the remote is maybe worn out ?
3 REPLIES 3
Message 1 of 4
You're Welcome 🙂
Message 2 of 4
Thanks Karl, hopefully that will sort it out, did wonder if the Huawei box was still supported.
Message 3 of 4
Hi LibbyB
I'll get a replacement remote out to you.
