on 01-09-2025 10:20 AM
I have a Samsung Frame Smart TV which has its own box. Is the TalkTalk Hub compatible with it?
on 01-09-2025 10:24 AM
Hey there, yes, the Samsung Frame Smart TV is compatible with the TalkTalk Hub. The compatibility primarily depends on the internet connection rather than the specific brand of the hub. Here are some key points to consider:
Aspect
Details
Internet Connection
The Samsung Frame Smart TV requires a stable internet connection, which the TalkTalk Hub can provide.
Wi-Fi Standards
Ensure that the TalkTalk Hub supports Wi-Fi standards (like 802.11ac) that the TV can connect to.
SmartThings Integration
The TV can be integrated with the SmartThings app, allowing you to control it alongside other smart devices.
Setup Requirements
Both the TV and the TalkTalk Hub should be connected to the same Wi-Fi network for optimal performance.
If you have any specific features or functionalities in mind that you want to use with your Samsung Frame Smart TV and TalkTalk Hub, feel free to ask!
Kanya
