Hub
Idsall
Message 2 of 2
Have just received a Hub and set it up. Can it be transferred from one TV to another and back without re-setting?
1 REPLY 1
Message 1 of 2
Yes, once set up there is no reason you can't move it to a different TV, unless you move it to a TV that has an aerial facing towards a different transmitter, in which case you may have to perform a retune.
