Search function
Conlaw53
Message 2 of 2
When searching for a programme to watch. Why does the earliest episode come up first and you have to scroll across through hundreds of episodes to get to the most recent ?
1 REPLY 1
Message 1 of 2
Because most people watch a show from the start.
Depending on the box you can select series first to get to the later episodes.
Also, depending on the box, it will go to the last viewed episode if you have previously watched part of the series.
