TVHub not playing recordings unless rebooted every time
grawa
Message 7 of 7
My talk talk hub records programmes but won't play the back unless rebooted every time
6 REPLIES 6
Message 1 of 7
Great, pleased to be of help.
Message 2 of 7
Having done a maintenance reset all is now working OK with recordings playable
Many thanks
grawa
Message 3 of 7
Have done software reset as advised and will check tomorrow if this has solved the problem
Message 4 of 7
The box hard drive may be failing.
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but if recording is important to you you will need to try as TalkTalk no longer provide boxes that record.
Hope it works but let us know how you get on
grawa
Message 5 of 7
My set top box is Huawei
Message 6 of 7
Which box do you have as the TV Hub does not record?
If you let us know we can advise further.
