TV Box stopped working
Iggypig84
Message 3 of 3
I have a small TV box, model: UZW4054TTG that has suddenly stopped working. I have tried unplugging, resetting, changing the batteries in the remote, but nothing seems to help, there is no light on the box.
Is it completely knackered?
Philile-TT
Message 1 of 3
@Iggypig84 did you try what @fr8ys has suggested? Did it work?
Phili
Message 2 of 3
Sorry the model number doesn't help? Is it a Netgem box or a sagmcom (TV Hub) one?
Try unplugging for 30 minutes then retry.
If it's a Netgem box, press the button on the left hand side 5 times. Hopefully this will reset it.
