TV hub & TV
Dwdotty
Message 3 of 3
ever since I replaced my old Talk talk player with this new hub I have been having problems that I did not have with the old set up. Whilsy the hub an tv work ok if I put on another TV  both sound and picture is out of sync with both Tv's, this is very annoying if I am in the kitchen cooking with one tv and the sitting room with the hub is on with the same programme, there is time delays with picture and sound. I did not have this with the old talk talk tv box. Is there and answer or have I just got to put up with it.
Thank you, gratful for any suggestions.  I have retuned both Tv's
Message 1 of 3
Thank you for taking the time to reply. I had a feeling that was the case.
Message 2 of 3
This is down to how the tuners on individual devices work and there is, unfortunately, nothing that can be done.
You were fortunate that there was a measure of synchronisation on your old setup.
I have 2 TV's, and different boxes attached to each and none are in sync.
