TV Hub hand set/remote
Shea4986
Newbie
Message 3 of 3
I could do with h diagram of the new hand unit to explain what all the buttons do,
how do I get subtitles on ?
Message 1 of 3
just to add, some apps sch as the channel 5 player may not always respond to the subtitle button on the remote. I found I had to turn these on within the app itself.
Message 2 of 3
Details can be found here
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
If you click on the picture the button controls are explained
