Tv box indicator lights constantly flashing
on 06-09-2024 07:42 AM
Message 3 of 3
3 lights on front of box will not stop flashing. Have tried turning off and resetting
Labels:
- Labels:
Settop box
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 06-09-2024 07:54 AM
Message 1 of 3
When you say resetting, have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings and if this does not work, unfortunately your box will have reached the end of its life as the hard drive has failed.
If you would like a new box from TalkTalk please note the no longer supply recordable boxes and you will probably need to recontract to obtain one.
If so, try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
You could also research purchasing your own box on the retail market. If you do this and are paying the TV fee, then phone the number above and ask for this charge to be removed from your bill.
Let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-09-2024 07:52 AM
Message 2 of 3
Hii
Can you try a Youview Maintenance Reset
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
