TVHub not starting TV
Liviu1
Message 3 of 3
Is it possible to have make the Hub start the TV when I turn the TVHub on?
Message 1 of 3
How are you getting on?
Message 2 of 3
If your TV is CEC enabled and one for which YouView have the appropriate codes for then yes. Not every make or model can be linked though.
Instructions can be found here
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
