TalkTV 4K Box 4 min. Recording Delay
Crusader300
Message 8 of 8
Hi, When I record onto the memory stick, the majority of the time it starts 4 minutes later than the program scheduled time and I therefore miss the first 4 minutes of the program. this mainly happens on series recording, but also on singular. The box starts up before hand with the light coming on at the front of the box. There is nothing else trying to record around the start time and I'm not watching anything else at the time.
Is there a setting or is it just a feature?
Chatty Man
7 REPLIES 7
Message 1 of 8
No Problem 🙂
Message 2 of 8
Hi Karl
Leave it as it is. Let's see if others report it to see if it is my box or as you say triggered by the broadcaster.
Joe
Chatty Man
Message 3 of 8
OK, all recordings are triggered by the broadcaster, but if you think the box itself could be at fault, we can swap this out.
Message 4 of 8
Hi Karl
Yep, done that also, no change.
Joe
Chatty Man
Message 5 of 8
OK, you could try a reset of the box to make sure its working as it should, but this will make you re-format the usb stick to initialise it.
Message 6 of 8
Hi Karl
Thanks, I have tried that.
Joe
Chatty Man
Message 7 of 8
start times for recordings are triggered by a signal from the broadcaster, so we / you are unable to affect this.
Try leaving the box on and see if the recording starts sooner.
