on 20-11-2023 12:11 PM
After a discussion with Talktalk about the problems I was having with my TV box I was told a new 4K box would be the solution - this arrived a few days ago. I followed instructions for set up and all seemed well until I did a channel scan which brought up no results - I can only receive digital channels - no terrestrial ones. The TV guide starts at no. 836 - no sign of BBC channels. Screen also told me no region was available either.
Could this be because my TV is 3HD and not compatible with the 4K box? (My TV works perfectly fine.) I was not asked about my TV before I was sent the new box. Your help would be appreciated. Thank you.
Monday
Glad the TV Box is working now. The Remote cannot cannot control the TV directly so you may need the TV Remote also.
on 23-11-2023 04:52 PM
Thank you Karl,
You were right - the problem was with the aerial - although plugged in, it had become slightly detached so not working. All is fine now and I have all the channels.
The instructions for setting up the box suggest there is an option to change the HDMI selection on the remote but the remote that came with the box does not have that option, unlike my previous one. Does this mean I am going to have to always use 2 remotes to access programmes on the new box?
Thanks again,
Poppy
on 22-11-2023 08:05 AM
The 4K TV box must have a terrestrial aerial plugged directly into the aerial port on the back of it. Any satellite cable etc will not work, his must be from a standard external aerial and must plug directly into the back of the 4K TV box for it to tune the channels.
on 21-11-2023 07:10 PM
Hi again,
on 20-11-2023 12:17 PM
Do you have the Aerial cable plugged directly into the 4K TV Box or the TV ?
