Talktalk hub , keep losing the apps, only had the box for less than a week
Clyford
Message 3 of 3
Keeping losing the apps , tried plugs in and out , router of and still no apps, only had the Hub for less than a week.
Message 1 of 3
How are you getting on?
Message 2 of 3
If you press and hold the home button this should take you to a screen that has all installed apps on it. They don't all appear on the carousel screen
You can also view them by going to settings, then apps.
