Thursday
When we turn of the TV either via the on/off button or the TV button, when we press one of the buttons to turn it back on the box is always off-line. Is this normal or just a pain?
Thursday
Yes that is the box.
I will set the standby to 12hours.
Thanks for your help.
Thursday
If its the android TV HUB, there are 2 power buttons on the remote, one for the TV and one for the box. When putting my TV in to standby here for a few hours, the box remains on when I turn the TV back on, but if the TV is off over night, the box will be in standby. Think I've set the time out to 12 hours.
Thursday
Hi Karl
Thanks for replying.
It is the latest small box, if that helps. Do I assume from your reply that it must remain on standby. If so why does it go off when we press the on/off TV button?
Thursday
Which Box is it that you have ?
The TV Box will usually have a standby time that can be adjusted in the settings and changing this can help.
