Tv recording box message YVM102
Annie9896
Message 3 of 3
Box says Guide preview unavailable  -BUT it is available
Apps - NOT Available
PROGRAMS ARE RECORDING
MESSAGE SAYS BOX NOT CONNECTED TO INTERNET
I HAVE RESTARTED ROUTER OK  BUT SETTINGS ON TV SAY CANNOT CONNECT TO INTERNET.
Have tried rebooting tv box but still getting same message
any help would be appreciated.
many thanks
Ann
Annie
Message 1 of 3
Hi there @Annie9896 , we are so sorry you are contacting us about an issue with your service, kindly try the troubleshooting advises provided by @fr8ys and let us know how it goes.
-Fez.
Message 2 of 3
Unfortunately these boxes are approaching the end of their life and to cause various issues.
Do you use power line plugs to connect the box to the router?
If so are all lights on on both of these? Have you tried resetting them using the pinhole and then re-pairing them?
If it's directly wired to the router then try and alternative ethernet cable as this may have failed.
If nothing else works then you could try the following but please be aware, if there is a problem, it could cure the box, but it could also break it given the boxes are no longer supported and approaching end of life, usually due to hard drive failure.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you it's the final option available.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box, but other options for recordable boxes are available from some retailers (see the pinned not regarding ITVX at the top of the TV forum page).
Hope it works and please let us know how you get on.
