on 25-05-2024 08:25 PM
TV signal is weak or lost showing codeyvm4302
on 28-05-2024 08:17 AM
Did you connect the aerial directly to the TV to see if there are channel issues in your area ?
on 25-05-2024 09:53 PM
Is it just on certain channels?
What's the signal like if you put the aerial directly into the TV?
Mine has been playing up today and it's probably weather interference. Don't retune as it could make it worse and hopefully it will improve in a day or so
