Various problems since having full fibre fitted
padley8634
Message 2 of 2
Since having full fibre my Tv has developed several faults
During a recorded programme it will suddenly go blank and then go through the start up procedure
When adjusting volume we get this really loud voice saying volume set at whatever selected
Also when switching on it takes up to a minute to go through the set up procedure every time
Also unable to get ITV X
Any help would be appreciated
1 REPLY 1
Message 1 of 2
The change to fibre should make no difference to the TV box.
Regarding the voice it sounds like an help function somewhere has been switched on but I've not heard of this before with the box. Could it be your TV  giving this advice?
As for ITVX, Please see the pinned post at the top of the TV forum, here.
https://community.talktalk.co.uk/t5/TV/ITVX-and-TalkTalk-YouView-boxes/td-p/3010612
As for the box playing up, have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
