Loss of sound on tv programme.
JoggyBoy222
Message 2 of 2
The sound on channel 21 has gone . The Picture is OK but no sound . Tried retuning all channels  -no effect. Tried picture quality on Channel 21  showed strength 25/26 Quality 99/100.. Any Ideas what to do next. It only started yesterday , prior to that perfectly ok. Other tv,s in house sound on channel 21 OK.
1 REPLY 1
Message 1 of 2
The signal strength may be the issue but the weather is playing havoc with signals at the moment, so this may be the problem and it's usuall best to leave retuning alone.
If you wish to recontract try and force it another retune may work, but first remove the aerial and retune. This will show 0 channels but will clear the box of it's memory. Then retune with the aerial in.
Hope it works, but if not post back
